Browse Forums Heating, Cooling & Insulation Re: Noisy outlet 4Jun 20, 2013 8:28 pm Sorry. Must be different then. The one we had years ago was up in the roof space, I don't remember ever noticing any exhaust pipe, but then it wasn't making any noise. Does the pipe wobble much? Is it possible it has been installed a bit sloppy-like and just needs some tightening to stop rattling around or something like that? Anyhoo, I hope someone who knows about these things can help you. Re: Noisy outlet 5Jun 28, 2013 9:25 am JazzyJess Sorry. Must be different then. The one we had years ago was up in the roof space, I don't remember ever noticing any exhaust pipe, but then it wasn't making any noise. Does the pipe wobble much? Is it possible it has been installed a bit sloppy-like and just needs some tightening to stop rattling around or something like that? Anyhoo, I hope someone who knows about these things can help you. The ones in the roof have a chimney. As for the OP where is your heater. In the roof, under the house or outside? Re: Noisy outlet 7Jun 30, 2013 9:47 am In which case there must be a flue (like a chimney) coming out the side of your house and I gather that is what is making the noise. Generally a whistling sound. In which case there isn't much you can do about it, there is no muffler. Hi, I have a double and whenever the wind picks up I can hear alot of banging in certain areas of the house. I've had a look round and can't see any obvious issue but… 0 10649 DIY, Home Maintenance & Repair Thanks Chippy . Did also see a YouTube video before. Removed them . Thanks again for the advice. 2 13962 |
