Browse Forums Heating, Cooling & Insulation 1 May 25, 2013 8:27 am Was wondering if loose fill insulation looses it's R value overtime as it becomes compacted? If so by how much? The reason I ask is my house in Canberra which is now just over 12 years and had loose fill insulation installed (not sure what it is made of but know it isn't a paper based insulation it is more 'wool' like), think at the time R3 was the norm. Looking in the roof now it is now basically one compacted mass as opposed to the full fluffy 'mix' it was when first installed. I understand that bats loose R rating if compacted so don't think loose fill will be any different either. Re: Loose Fill insulaton 2May 25, 2013 9:23 am AJW Was wondering if loose fill insulation looses it's R value overtime as it becomes compacted? If so by how much? The reason I ask is my house in Canberra which is now just over 12 years and had loose fill insulation installed (not sure what it is made of but know it isn't a paper based insulation it is more 'wool' like), think at the time R3 was the norm. Looking in the roof now it is now basically one compacted mass as opposed to the full fluffy 'mix' it was when first installed. I understand that bats loose R rating if compacted so don't think loose fill will be any different either. It's all about the air that is trapped, less height, less air. Measure the depth now versus the depth when new, the ratio is how much efficiency you have lost. You could top it up... what is already there will be slightly less effective than equivalent new, but much better than not having it there. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Loose Fill insulaton 4May 25, 2013 9:38 am AJW Thanks, that's what I though. Bit hard to measure what was there when new, but I know it was a lot higher than it is now. It is now a few cm at best. I think it would have been 100mm, that's what mine used to be a long time ago. Top it up if it worries you, or you could try loosening it... if you took it all out and put it back it would be a lot better than it is now... if you can be bothered. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 A Sabco spin mop, minimal moisture, not very regularly. I was told these hybrids are water resistant 🤷♀️ 2 7620 2 4343 yeah i couldnt picture it issue either, but i could clearly picture what they were doing wrong haha 2 5289 |
