Browse Forums Heating, Cooling & Insulation Re: Insulation for home theater? 2Feb 24, 2013 12:25 am This is very general, as you didn't specify what build stage you are at. Depends on budget, and what stage you are up to. From simple to sky is the limit. Several insulation companies have specific Isolation products, Knauf, Boral and the venerable Rockwool, though installers don't like the fibres. A Boral Guide http://www.boral.com.au/brochures/order ... 0_DC&scr=4 In studios I have been involved in building, it's not just Insulation, but mass. Staggered stud walls help a lot as well. If you can afford it, 2 x sheets of 16mm plaster is good. Lay the 2nd at 90 degrees, and seal all joints properly with an acoustic sealant. You might have to do 3 thinner sheets on the ceiling, as 16mm is heavy. Does not need to be FyrCheck. Airtight is sound tight. Solid Core doors, with full Raven seals, including the Threshold. Windows, you can get Double Glazed ones, with a bigger air gap to reduce noise, though you sacrifice some of the heat benefits. Re: Insulation for home theater? 3Mar 01, 2013 6:43 pm I used Rockwool acoustic batts for our home theatre walls and R4.1 ceiling batts in the subfloor. I also have Hebel power floors instead if yellow tongue board to my top floor. Can barely hear a thing out of the home theatre. Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11273 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6191 |
