Browse Forums Heating, Cooling & Insulation Re: Help - Heating / Cooling - tank water and no gas 5Feb 25, 2013 10:19 am wirlz We can get evap cooling installed or have $5,000 to spend on upgrades but being on tank water I'm wondering if it will use too much water? I like the idea of outside air coming in and I'm not worried about the odd day that it doesn't work because its too hot/humid. The advice from JB1 is on the money. With evap air con, people often refer to the dump rate. This use to be 10-12 L per hour on the older models but newer design have this down to 3-4 L per hour. This figure however is insignificant when compared to the amount of water that is used per hour to provide the cooling from an evap air con. You are in the Yarra Valley and Victoria now experiences long dry summer periods. Given that you are on tank water and you would be using the air con during the dryest and hottest period, evap air con would not be the best choice. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10808 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20224 18 90473 |
