Daikin or Hitachi
1. Daikin Premium Inverter FDYQ160 - (1) 16.0kw (6HP) 1 phase, Reverse Cycle, Dry Mode, Ventilate
Daikin 14.1kW High Static Inverter Ducted System. This single phase unit has a cooling capacity ranging from 6.2kW to 15.0kW and a heating capacity from 6.2kW to 18.0kW.
2. Hitachi Inverter RPI-7.0/RAS-7HVRN - (1) 8.1-20kw (7HP) 1 phase
3. Daikin Premium Inverter FDYQ180 - (1) 10.8-20kw (7HP) 3 phase
Daikin 18kW High Static Inverter Ducted System. This three phase unit has a cooling capacity ranging from 10.8kW to 20.0kW and a heating capacity from 12.0kW to 22.4kW.
Not really sure which one to choose. Been told that for option 3 we'll have to sign "noise waiver" as it might be louder than the other two.
Thanks
We had Carrier, Kelvinator and Daikin in Darwin...I'd go for the Daikin
In Alice Springs we had DL (offshoot of LG) and Mitsubishi units...both seemed to work well.
In Perth we have Fujitsus, work well in heat, haven't used the for cooling yet.
Any reason you have gone for these two brands?
Been quoted by Ford and Doonan these three units. We asked for ducted aircon and gave them our plans. That's what they came back with. It has 8 zones, 10 outlets and 2 return air grilles. Not sure about Actron though as previous post suggested. All quoted aircons were in $15,5-17k range. So we're not sure which one would be better. Don't really want huge unit sitting outside but need something that can handle the house in 40 degree heat.
We are heating/cooling 36sq. Didn't bat an eyelid in recent 40 deg days. At times was even shut down.
Not sure if this applies to all models.
The parts that we need circuit boards and motors are no longer made by the firm that Hitatchi had make them (that firm went into receivership) and there is no customer support.
At the moment ours is going due to canobilised parts of other Hitatchi's.
