Browse Forums Heating, Cooling & Insulation 1 Nov 28, 2012 4:53 pm We got the keys to our new split level house with open plan living above the kids bedrooms, play area, hallways. We'd specified soundscreen / soundproofing batts to the entire subfloor, as well as the hallways. On closer inspection we found they missed it. What is the best way to install insulation / soundproofing at this point? I'd thought about spray in foam via the downlight holes to minimize damage, but apparently this can't be done. The builder wants to cut a hole in the downstairs ceiling and blow in insulation to the subfloor and cut out a section in the halls to stuff batts up / down past the noggins. Re: Builder forgot soundproofing, how to rectify? 2Nov 28, 2012 5:07 pm dunkit We got the keys to our new split level house with open plan living above the kids bedrooms, play area, hallways. We'd specified soundscreen / soundproofing batts to the entire subfloor, as well as the hallways. On closer inspection we found they missed it. What is the best way to install insulation / soundproofing at this point? I'd thought about spray in foam via the downlight holes to minimize damage, but apparently this can't be done. The builder wants to cut a hole in the downstairs ceiling and blow in insulation to the subfloor and cut out a section in the halls to stuff batts up / down past the noggins. I would let the builder do what he wants. But I would also ask him to appoint an acoustic engineer like... http://marshallday.com/regionpage/marsh ... -australia. Then measure the before and after, to see if it has been effective. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Builder forgot soundproofing, how to rectify? 3Nov 30, 2012 9:31 pm Thanks for the advice. From what I can gather blown insulation isn't common practice anymore, but I did come across granulated rockwool from Bradford - http://www.bradfordinsulation.com.au/Pr ... -Fine.aspx It's a commercial product that would be more costly, but Bradford only had 3 x 12.5 kgs bags in stock and 6-8 week lead time. After speaking with their insulation department for possible installers, they effectively said you can't do blown insulation into a subfloor. I gather you can't get a consistent uniform layer by simply pushing the hose around through the posi-struts. They suggested the only way to do it correctly would be to remove plaster and install soundscreen batts as original intended. Obviously the better solution would be to also install heavier plasterboard like Gyprock Soundchek - http://www.gyprock.com.au/oursolutions/ ... tions.aspx I spoke with the builder and asked them to remove the plaster and install rockwool batts, so we'll see how we go. Re: Builder forgot soundproofing, how to rectify? 4May 22, 2013 1:12 pm Just wondering............ What was the final outcome ? Hope it went well for you ? Cheers, P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 If you don't want to annoy the neighbours then simply get yourself some good head phones. For me the sound is much better using headphones. The NCC (National Construction… 1 26171 Upgrading your windows to soundproof ones, like triple-glazed, can make a significant difference. While changing window… 4 11665 Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 9156 |
