Solar Hot Water and Electricity !
We also wanted the Solar Electric.
Question - would 3KW elect system be adequate - since we have Solar Hot Water - or would 5KW be better. Keeping in mind costs etc etc ?
I see some providers also give you up to 9% extra for paying well etc. I presume this is off the cost AFTER the solar is taken into account.
Thanks - SJ
With gas boosted solar we have been using around 16kw per day so we would need 5kw of panels to offset our total electricity usage.
Being in Queensland you may generate a bit more power.
If you are going to have a big area of panels (on a north facing roof) you might need to think about where the hot water panels would be. This link has a suggestion. http://www.anewhouse.com.au/?p=3604
From what i can work out 3kw of electric will work well. And save a bit too.
I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be…
16/04/2024
2
the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you…
11/01/2024
Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks…
