Browse Forums Heating, Cooling & Insulation 1 Aug 07, 2012 1:55 pm Hi, Can anyone recommend a good Gas Boosted Solar Hot Water System? I've found Dux Sunpro 305 Gas Boosted Solar from Bunnings. How do they rate? Thanks I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20197 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 12118 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24133 |
