Browse Forums Heating, Cooling & Insulation 1 Apr 01, 2012 2:11 pm Hi all, Im building a new home and after some advice for heating and cooling for a 26sq living house in leopold victoria, so far have been told conflicting ideas as to whether i should get gas ducted heating with add on cooling or a full electric aircon heating unit e.g daiken unit am unsure which way to go if anyone could help with pros cons would be great thankyou Re: gas ducted heating and aircon 2Apr 02, 2012 2:15 pm For Victorians you are best to go for Gas Ducted heating and add on cooling. Diaken is nice to have in areas where you use aircond more than heating. GAS especially if you get high efficiency is much cheaper to run than electric. Add on cooling is good to as long as you have it installed properly. Re: gas ducted heating and aircon 3Apr 02, 2012 3:21 pm I am in Adelaide but when we were renting we had a gas ducted heating system which cost a fortune to run as the whole house had to be heated - it was obviously a cheap system with no zones!! We were paying about $400 a quarter for gas and our first gas bill in our new house was only $81 although it wasn't winter - we have reverse cycle where we are now and solar hot water with gas back up. We are very happy with the air con and thanks to good insulation haven't had to use it too often. Hope that helps ... For info on our build: viewtopic.php?f=31&t=43093 Built the McLaren by Dechellis - slab down 22 Feb - handover 30 Aug 2011 - and gardens finished 9 Dec 2012!! Re: gas ducted heating and aircon 4Apr 02, 2012 8:21 pm This is of course assuming you have natural gas available. Becomes cost prohibitive using LPG. Slab heating is much the same with out bills in N/E vic being about $1200 a qtr for heating along. Reverse cycle here we come. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: gas ducted heating and aircon 5Apr 03, 2012 7:41 pm Hi ADS, we live in Adelaide and we installed ducted gas heating with zones and it our bill was the same as our old house which had a wall furnace. We then installed ducted evap cooling which is so cost effective. We've found that both units work well and are energy efficient. It did cost more than installing ducted reverse cycle but we figure it will pay for itself within a year or two. Good luck Handover February 2011 Happy with our home The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15800 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 13792 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20237 |
