Hi, I've got a Braemar ducted gas heater TE/TX
last year I replaced the gas solenoid because the pilot wasn't lighting, and it worked fine all winter.
(the service tech I got out said the valves are over $500 and that's if you can even find them.. I found one at tradelink for $120!)
anyways, this year I've got a new issue, the pilot is lighting and the main burner ignites but the fan doesn't spin up. the fan works because in cooler mode it spins.
I'm assuming it's not sensing the flame for some reason?
On the circuit diagram in the box, there is a flame detector module. (looks like an old wet film canister with a pipe coming out of it) anyone know how these work?
I have to go back in the roof and look for a thermal couple, or anything else that could be damaged..
anyone have ideas?
Thanks
Mick
