Browse Forums Heating, Cooling & Insulation Re: Hydronic Heating - Which Brand to Choose? 81Feb 08, 2017 7:55 pm Hoping to restart this thread. Interesting speaking to various installers the different opinions you get. It seems to be there are 2 camps (Bosch resellers vs the rest). Has anyone had experiences with the Bosch units? Re: Hydronic Heating - Which Brand to Choose? 82Jul 26, 2017 2:02 pm Hi all, great forum! In the process of building two 4 bedroom houses (27 sqm) to live in (2nd house for parents). I got quotes from Cambro Hydronic Heating (CHH) & Hydronic Heating Systems (HHS). Heating area would be 16sqm for the ground floor. CHH - $10k with Immergas SE32kw HHS - $9k with Sim Brava 30 BFR e Both with PE-Xa Rehau pipes After reading the posts i wanted to understand a couple of things ... esp as 1960sModernistHome's post has made me start more research!
Re: Hydronic Heating - Which Brand to Choose? 83Jul 26, 2017 9:22 pm 1, Yes you can get a combi boiler and use the second loop for domestic hot water. I do this at home. 2, From my experience, I'd say you still need panels upstairs though they don't need to be sized as large. There's also the option to fit thermostatic heads to close down each panel when the rooms they are in are up to temperature so you don't keep heating rooms upstairs unnecessarily. If I was doing it again, I wouldn't installa panel in the upstairs living area 1, Geothermals work great, better than air or water cooled as the ground temperature is more constant all year round. The only disadvantage is it's not widely adopted so is more costly to purchase and install first up. 1, It's not worth feeding into the grid at 6.6c pay back per kw/h. You're better off looking at battery storage systems instead and only feeding in any excess you're not using. hth Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 4869 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 4794 Thank you. That is really helpful. Once we get the place done and passed for OC we can upgrade in the future once we get back on our feet and not paying mortgage and rent. 4 5712 |
