Browse Forums Heating, Cooling & Insulation 1 Feb 20, 2012 9:16 am Hey h1 been looking at using steel framed 'supaloc' for our build and they are offering insulation between the frames now called thermaloc. http://thermaloc.com.au/ has anyone seen anything like this? seams to have quite high R-value's and seals to the frame, including walls/ceiling and roof havent found much on google other than their main site. thanks, 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Re: Thermaloc - foam insulation for steel frames 3Feb 20, 2012 5:44 pm james_d Looks good, though i have never seen expanded polystyrene used in insulation - only extruded. i did a quick search what is better for home insulation? http://www.truefoam.com/en/home/aboutep ... ruded.aspx 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17986 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14530 Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 4204 |
