garage door insulation
A petrol can left on the garage floor exploded yesterday afternoon, due to the expanding gas.
When I got into the car it shows outside temp was 44 degree, driven out of the garage for a few minutes and it drops straight back to 32.
does anyone know of garage door insulation kit easily available from bunnings?
My garage is now at a closer temp to the outside temp.
Owens Corning Garage Door Insulation Kit
might do...
Jerry cans and similar containers are not vented like car fuel tanks and so the do build up pressure and can be dangerous.
The other thing is that in high temps the fuel vapors are more volatile and can ignite by a smaller spark source.
Putting a vent in the ceiling and using whirlybirds will help reduce the heat but the petrol can will still expand and contract with heat.
It does make sense if the outside temp is cold and you wanted to keep the inside warm.
But insulating the garage door panels wouldn't it make it worst after you've driven and parked your car? wouldn't it slow down the heat dissipation time?
Dover white or surfmist garage door. I am having trouble choosing a garage door. The outside of house will be tranquel retreat. I want it to all blend nicely however I…
15/12/2023
Hi, have purchased a house with 2 single garage doors. The Centre pillar one side sits proud to the other. Can I change 2 doors into one. Please see picture.
20/02/2024
My garage door has started playing up recently. Sometimes (and getting more frequent) when I press the button to open it, it wont. The motor is an ATA GD0-6V3. Red and…
