Browse Forums Heating, Cooling & Insulation 1 Jan 01, 2012 8:28 pm Hi all, Any ideas in this hot weather to decrease the roof space temperature ?.. ( and therefore the heating effect on the house in hot weather ) We have a high pitched, well insulated roof, but would the colourbond spinning roof vent things ( sorry ) assist? More insulation ? ( currently we have R4.0 ) Also, is there an insulated duct available... everytime the ducted refridgerated a/c starts, it blows 10 seconds of warm air ( presumably heated inside the ducts sitting in the roofspace ) Cheers and stay cool this week Re: Decreasing roof temp to assist a/c 2Jan 01, 2012 9:05 pm I recently installed two whirly birds in my roof. The main reason for installation was to assist with creating a negative pressure to help the exhaust fans work better throughout the house including rangehood. It worked in this regard straight away. I found that the room that I yet to insulate noticed some improvement, in the temp. I also feel that the house takes a little bit longer to heat up. I also added a vent inlet in the garage and I notice the temp in the garage is only slightly hotter then outside where before it used to be much hotter. If you can install them yourself it will only cost you a couple hundred and you cant go wrong, even if it just removes moisture. by the way are you actually running a/c or evap. Re: Decreasing roof temp to assist a/c 3Jan 01, 2012 10:24 pm We are running ducted refridgerated a/c... Interesting idea for the garage, ours isn't insulated and gets steaming ...will definately look into that. Re: Decreasing roof temp to assist a/c 4Jan 15, 2012 10:42 am What about a solarVenti? We've had one installed and to be honest it doesn't make a great difference to the room temperature but apparantely it makes A/C much more efficient. So will be interesting to see when we get the A/C installed. You can look at info at ges.com.au The guy who installed it said it's more than 10 times the effectiveness of whirlybirds. Re: Decreasing roof temp to assist a/c 9Jan 17, 2012 7:31 pm Althom Expensive and not very environmentally friendly way to reduce the temp in your roof space. Upfront yes, but if you look at TCO, then it's actually positive. If you use less efficient panels, they are cheaper, and cover a larger surface area, so pay back time is shorter. For most system, say for 4kW (which I have done the sums for), the payback time is about 10-12 years (using a figure of $1000 to $1200 actual generation payback per year), then you have the other 13-15 years of expected lifespan of solar panels to earn you passive income. This is also assuming electricity prices stay the same for the next 25 years, and no carbon tax. As far as environmentally friendly, there is an initial cost, much like anything else including plastics (drill for oil, refine it, etc), but long term-wise, you will be part of the solution as cheap energy sources decline. Re: Decreasing roof temp to assist a/c 10Jan 21, 2012 2:59 pm Althom Expensive and not very environmentally friendly way to reduce the temp in your roof space. Welll, you could then run a split system in your roof cavity with the electricity you produce..... That'd keep your roof temperatures lower than any whirlybird or e-vent could! Re: Decreasing roof temp to assist a/c 11Feb 29, 2012 1:20 pm Hi, we are looking at reducing our roof temp too. Have just order 4 smoothline ventilators (2 sets of 2) for our colourbond Dune roof. Will post when we have installed them and advise their effectiveness. http://universaltileventilators.com.au/ ... -vent.html Re: Decreasing roof temp to assist a/c 12Mar 13, 2012 4:17 pm So far, so good ... My husband installed them on the weekend. We have all commented that it definitely feels cooler upstairs, especially the night time, seems to cool down a lot quicker than before. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I have an updated photo of them installed on the backside of the roof. We are quite impressed with the difference they have made. Our upstairs is noticeably cooler. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Decreasing roof temp to assist a/c 13Jun 14, 2012 9:05 pm PHL On interesting option is to have solar panels on your roof, preventing direct sunlight on the roof. This doesn't make much difference... I have a north facing roof with solar panels and the radiant heat still comes through on a summers day. 2 9458 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28326 traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4225 |
