Browse Forums Heating, Cooling & Insulation 1 Nov 06, 2011 11:26 am Hi all, tried to search for an answer, so sorry if this has already been covered.. I am looking for a solution to the noise my 2 yr old split system " outside box" makes when the unit starts.. ( when the compressor kicks in??? ). It's a bong sound like the cover is being banged with a hammer. Anyone have a solution, doesn't bother me so much, but I don't want to disturb the neighbours. Many Thanks Re: Split System condenser noise 2Nov 06, 2011 8:09 pm Can you record it with a video and put it on youtube? What kind of AC is it? And what kw size is the unit? (if you get a pic of the copper pipes going into it i can make a educated guess, if you don't know the kw size ) Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 11786 Upgrading your windows to soundproof ones, like triple-glazed, can make a significant difference. While changing window… 4 11665 Move your linen into laundry and access laundry from your present linen space 1 8014 |
