Browse Forums Heating, Cooling & Insulation Re: Gas Heating + Evap Cooling 2Oct 02, 2011 12:35 am No, not only because they come from different units but you also need the vents positioned differently. The evaporate vents should be away from the windows pushing air towards the windows, while heating vents should be near your windows since that is the coldest place in the room. Chatz 4 10824 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20236 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3664 |
