CENTRAL HEATING IN ROOF - HEAT LOSS THROUGH VENTS
We have a very well insulated and draft-proof home with an efficient and powerful space heater that heats most of our home up very well. We hardly use the central heating system at all - probably on average about an hour a week, or two hours in the depths of winter. The problem is that the vents are not that easy to open and close and I can't expect my wife to go round the house and open them all up when she wants to use central heating.
I've been told that the open vents in the central heating system are a major cause of heat loss as they form a very effective thermal cooling current, especially at night. They are not as well insulated as the rest of the house and so heat escapes from the rooms into the ducting and then out into the roof. It makes perfect sense to me, and I am also aware that these small breaks in insulation have a major impact on the insulating quality of my insulation 'blanket'.
My ideal solution to this is simple - turn the thing off, plug up the vents with insulation, and save more heat than we gain from the system. But this is not a suitable solution for the boss.
Does anybody know exactly how much heat loss occurs through an open central heating vent, and are there any simple solutions?
I have the R1 ducts and they seem to be pretty insulated(~2" polyester) so I doubt that much heat would be escaping if the fan is not on.
It is estimated that a 5% uninsulated area in a roof caused about 50% decreased in total insulation cover and the reason for this is that heat rises to the ceiling and will naturally go to where it can escape (to where the gaps are). So if a roof has open holes leading to a large 'less insulated' area, you are effectively providing an easy escape route for heat, which undoes all the work of putting the large amount of insulation in the rest of the ceiling.
I would say that R1 is not enough for ducting - one of my options is actually to increase this - probably by wrapping it in a foil reflective blanket.
Also any un-insulated area is effectively equivalent to 10 times that area uninsulated. This obviously doesn't count where there is some insulation there.
4
retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you…
11/07/2023
Hi, just need to ask if anyone build with Central Properties in Victoria. Thankd
28/02/2024
Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small…
