Browse Forums Heating, Cooling & Insulation 1 Jul 11, 2011 11:17 pm i've got myself two commercial quantum heat pump hot water systems holding 340L of hot water each, and 7 hydronic heater panels... i've read a bit around the internet about using potable house hot water and running it through the hydronic panels, as well as using that same hot water routing system in the kitchen and bathrooms etc. for general hot water use. Can anyone give me details of fittings and plumbing that i require to accomplish this? ideally a diagram with labelled parts like 'expansion tank' and 'manifold' - i'm getting a bit confused as to how the water circulates back into the hot water systems and somehow automatically refills from the cold tap if some hot water is used in the shower for instance... there must be a controller of some sort, and is this passive or active? thanks in advance, i'm sure i'm not the only one looking for this kind of system. Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 4890 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 4822 |
