Browse Forums Heating, Cooling & Insulation 1 Jun 12, 2011 3:39 pm Hi, We are building a new home and asked our electrician about built in outdoor heating and he said not to bother as it would be around $6000 plus expensive to run. Just wanted to see if anyone has considered or has built in outdoor heating and whether these costs seem right? He told us that a portable gas heater is the only real option unless money is no object. While we like the heat that comes from these heaters, they are big and have to change the bottles so would prefer something else. Anyway, if anyone knows an effective and reasonable heating option it would be appreciated, Thanks! Re: Alfresco heating options 2Jun 12, 2011 6:46 pm If the conditioned area is not airtight and insulated then you will lose a lot of heat. It will cost a fortune to run. If you are really keen then pure radiant heating directed at the occupants is the most efficient. Re: Alfresco heating options 3Jun 13, 2011 10:11 am we are building an alfresco thats about 9m by 5m'ish we are putting a combustion heater out there as we have a second hand one in the house we are in now and will take it with us. we live rurally so obtaining some wood isnt a problem for us. just need an extra power point put outside when we build to run the fan in the combustion Re: Alfresco heating options 4Jun 13, 2011 10:27 am Wall mounted gas heaters, LPG or Natural http://www.stargas.com.au/lp-gas/products Landscape Design & Construction http://cherub.squarespace.com/ Re: Alfresco heating options 5Jun 13, 2011 3:05 pm A convective heater heats the air which then just gets blown away by a open area. Radiant heat transmits heat directly to the nearest solid object. Alfresco heating options 6Jun 13, 2011 3:33 pm Have you considered an ethanol heater? Our alfresco has 3 walls so we will most likely get a Cocoon fireplace. A plus is they don't need to exhaust. They are about 3-4k and in summer can be filled with ice and used for drinks http://www.cocoonfires.com/products.htm Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4191 Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 4877 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1617 |
