Browse Forums Heating, Cooling & Insulation 1 May 09, 2011 11:07 pm Edited to include pic
We have a BAL-12.5(ember attack) and require our colorbond roof to be fully sarked. Does that mean there should be no gaps? Taped at joins? No ridge caps showing? Should we be concerned and hire a building inspector? see pic: http://img849.imageshack.us/img849/3280/s6300721.jpg Re: Help- what does fully sarked mean? 2May 10, 2011 9:09 am The sarking is a reflective material which is installed underneath the colorbond itself. Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Help- what does fully sarked mean? 3May 23, 2011 10:09 pm Thanks Deemaree. Still not sure on ridge caps- any advice appreciated Tried to include pics but couldn't????? Re: Help- what does fully sarked mean? 4May 26, 2011 10:24 pm I would contact your local authority - in VIC here are the standards and contacts (see link) but in a nutshell (and not entirely clear but 12.5 yours "seems" fine Bushfire Attack Level Summary of special construction requirement Clause BAL 12.5 (a) Roof tiles, roof sheets and roof-covering accessories shall be non-combustible. (b) The roof/wall junction shall be sealed, to prevent openings greater than 3 mm, either by the use of fascia and eaves linings or by sealing between the top of the wall and the underside of the roof and between the rafters at the line of the wall. (c) Roof ventilation openings, such as gable and roof vents, shall be fitted with ember guards made of non-combustible material or a mesh or perforated sheet with a maximum aperture of 2 mm, made of corrosion-resistant steel, bronze or aluminium http://www.pic.vic.gov.au/resources/doc ... _sheet.pdf You get what you pay for! Re: Help- what does fully sarked mean? 6Jun 12, 2011 7:09 pm As a general rule if you are in bushfire prone area consider the sarking as secondary protection. It is better to ensure there are no gaps in the roof structure for the embers to enter in the first place. i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12711 I've just built 3 stairs off a landing out the back and been told by the private certifier I need hand rails sorry tried to attach a pic but couldn't mine don't have sides… 5 5704 Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12645 |
