Hi There,
I have a Braemar Gas heating system which wont come on.
It displays RESET and the Code -07
Could anyone enlighten me as to what this means?
Are the codes available anywhere incase I get a different code down the track?
Thanks!
Browse Forums Heating, Cooling & Insulation 1 May 08, 2011 5:27 pm Hi There, I have a Braemar Gas heating system which wont come on. It displays RESET and the Code -07 Could anyone enlighten me as to what this means? Are the codes available anywhere incase I get a different code down the track? Thanks! Re: Braemar Heating Problem 2May 27, 2011 1:14 am There is an issue if a fault code comes up - I do not have the fault codes at hand right now. I would power off (at the board) and power 5 mins later to reset - is it sorted? You get what you pay for! Re: Braemar Heating Problem 3May 29, 2011 12:10 am Gas supply turned off Ignition led damaged or disconnected Incorret gas supply pressure Incorrect burner pressure Incorrect spark gap OT3 open (located on burner cover) EFS not dectecting flame signal-ignition occurs but gas turns off after approximately 7 seconds See how yu go with these 2 5860 I don’t think so as the floor area over 300 square meters then it is class 3…. 12 17943 Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 4889 |
