Browse Forums Heating, Cooling & Insulation 1 Apr 14, 2011 5:50 pm I do not understand so thin a layer of aluminum foil could prevent heat conduction. in my opinion as a metal Thermal conductivity of alum. foil is high than Iron, why aluminum is the popular choice to produce insulations facing or tape? Thanks! Re: why foil insulation could barrier heat or thermal radian 2Apr 14, 2011 6:02 pm Hi Welcome to the forum. The following link gives an explanation of reflective . http://www.anewhouse.com.au/?p=838 Regards Brian The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. We are tossing up between a Jarrahdale radiant wood fire (the Pioneer) and a convection wood fire (Innovator or Countryman) but cannot decide on which type of wood fire is… 0 5250 I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17045 Hi, I had a barrier reef pool installed less that 2 years ago and the gel coat is already fading. The colour is electric grey shimmer which isn’t available… 0 3824 |
