options for glass insulation
Obviously, make sure that draught gaps around the frames are dealt with. There is a down side to having a fully draught-less home; DYOR, Google, etc.
is right and it is the cheaper solution I have a noise problem so I went for heavier acrylic and wider gap with a rubber seal to suppress flanking noise but works just the same for extreme changes in temperature saving up to 70% heat loss through condensation. Actually condensation is good because it exposes where the heat loss occurs and give you a chance to fix it. Well at least this what I have done and at a fraction of the cost of magnetite or stop noise.
Why not get an idea how much it would be before you finish (unless of course the glass is in). We are going for double glazing in our extension/renovation, yes it is expensive and I'm not conviced it will pay for itself in reduced heating costs. BUT a comfortable home is what we want. Everyone is willing to turn up the ac in summer and the heater in winter, but less inclined to spend the money on a blanket for the house. I guess we will be ahead if energy costs go the way the hysterical TT type shows tell us they will. The other consideration is that we will be in our home for life... we love where we live and so the investment is sound
Cheers,
Chris.
17
Standard uninsulated double brick has an R value of around 0.7. An insulated standard 90mm stud timber frame can have an R value of around 2.7. Even if you insulate a…
8/07/2023
Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor…
16/07/2023
Howdy all. I am looking for feedback on what people would do to maximise and make an area as flat as possible. First, out the front of the house is a sloping hill, pretty…
