Browse Forums Heating, Cooling & Insulation 1 Feb 18, 2011 11:30 am Hi, I'm a first timer needing to install R3.5 earthwool insulation batts in the timber trusses between the ground and first floor. Trusses are 300mm deep and I'm installing from underneath. What is the easiest option to hold the insulation in place? I've read techniques including nylon, stiff wire fastener, perforated base hangers. The local supplies store recommends using iron hoop (flat metal strip). Is the insulation installed at the top or bottom of the truss? i.e. top pressing against the bottom of the first floor, or bottom to sit on the ceiling of the ground floor? Would the insulation be installed before or after electrical and air-con rough ins? With the first floor ceiling install, this should be easier installing from the roof cavity above the ceiling (top down). Could anyone offer any advice or considerations I need to be aware of? Thanks in advance Re: Installation of truss/ceiling insulation 2Feb 19, 2011 8:43 pm Hi I used to work for an polyester insulation manufacturer, and they provide comprehensive information including technical data sheets on their website. They also provide free phone advice on questions such as how to install in specific situations. Have you tried calling the manufacturer of your insulation? It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2205 Found the answer. The recommended distance is .... 1 5957 |
