Browse Forums Heating, Cooling & Insulation 1 Jan 17, 2011 11:09 pm Hi, we are currently putting together a list of items we would like to have included in receiving a quote from the builder. We are really stuck on the best option for heating downstairs. Our design is split level, with open staircase going down. This area will have three bedrooms, bathroom, toilet and small sitting/tv area. My first preference for heating, based on what I've learned is hydronic wall panel heating, but not an option due to costs. I don't mind having ducted heating at entry level, though am wondering if putting this down stairs will cause heat loss up the stairs. Will ceiling fans help with this? Can anyone suggest other options? I'm quite sure we will not need any cooling in this area. Your thoughts and suggestions are most welcome. Is anyone else building a similar design? Re: Heating options for split level, help please 2Jan 20, 2011 7:48 pm You will naturally lose some heat up the stairs but nothing that wouldn't or shouldn't be factored in the sizing of the system. Heating systems are generally thermostatically controlled so will cycle on/off based on set point temperature (what temp you want). Unless you have very tall ceilings you should not have any problem with heating You get what you pay for! Move your linen into laundry and access laundry from your present linen space 1 8016 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6468 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17528 |
