Browse Forums Heating, Cooling & Insulation 1 Jan 17, 2011 6:51 am Hi, Topic says it all really. I'm building a 2 story home at the moment. The house will have full ducted heating, but we said no thanks to the Evap cooling. I was just going to look at 3 or 4 split systems (or maybe a multi head system) but a mate said he had heard of people adding a unit that could use the existing ducts. Does anyone know of anything like that? Thanks, Milesy. Re: Can I add an air conditioner to existing Heater vents? 2Jan 17, 2011 1:44 pm that would be add-on cooling - http://www.brivis.com.au/content.cfm?content=147 the ducted heater and ducting has to be upsized to allow for the a/c though - that is probably what your mate is talking about Re: Can I add an air conditioner to existing Heater vents? 3Jan 17, 2011 4:28 pm As desclarkson has said add-on refrigerated cooling can be incorporated into a ducted gas heating system. Generally the gas ducted unit has to have 'extra air' to allow for the increased airflow required for the cooling you will find manufacturers have standard and extra air (XA) models. The ductwork also needs to be upsized to facilitate the extra airflow required (cooling) but still doesn't sit right with me in relation to size compared to a ducted refrigerated system but in Vic, they don't seem to mind You get what you pay for! Re: Can I add an air conditioner to existing Heater vents? 4Jan 17, 2011 4:32 pm We had a split system added to our ducted heated after the build. We have had it now for four years and we are happy with it. As others have said we had the size of the ducts increased by the builder and a slightlly different heater unit fitted. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Can I add an air conditioner to existing Heater vents? 5Jan 20, 2011 10:24 am Split systems it is then! Thanks for the advice. retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 13792 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110592 0 1353 |
