Browse Forums Heating, Cooling & Insulation 1 Jan 02, 2011 9:07 am My aircon is blowing out air but not cooling. I'm getting an error message on my Actron Air Conditioner which when I look up the faul codes it says - communication error between indoor and outdoor. As per my instructions I've tried turning it off at the mains and then on again. Has anyone had any experience with this sort of error? I'm hoping it's something I can fix myself rather than waiting for a repairman as I expect they are rather busy at this time of year. Re: Actron Air Conditioner - no cool air coming out 5Jan 06, 2011 8:34 pm Steve, You will know if the compressor is running as you will be able to hear it at the outdoor unit. Not likely if it is not cooling however. Communication errors ultimately mean the indoor and outdoor are not "talking" as they should. Simple reason is the interconnect cabling has come loose at a connection as B STAR has mentioned. Common when the unit first gets installed - not so much in my experience if the unit has been operating for a while. Possibly it's the PCB (Printed Circuit Board) The electronics in these units can be quite complex and a simple error in any number of boards can create problems / errors, communication or not. I'd say a warranty call if it's still under warranty (5 years residential) in which case contact either your installation contractor or Actron Air to place this. You get what you pay for! Re: Actron Air Conditioner - no cool air coming out 6Jan 06, 2011 8:36 pm Sorry, last post for natbut not Steve - apologies Re: Actron Air Conditioner - no cool air coming out 7Jan 22, 2012 2:17 am The only way to test know is to with a multimeter, I doubt its the compressor as the error code for compressor would come up, its probably the 2 core cable connection between the indoor and outdoor boards if you test between them you should get 6 volts , if one of the boards is faulty and your out of warranty don't get a new one as there approx $450 for an outdoor one and $300 for internal, just send it in to Actron and get it repaired, it should only cost about $50 then Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9070 Chemtrails, only the most disproven conspiracy theory in the history of conspiracy theories. You've gone in the deep end, drowned, and are now a mindless bloated… 5 86539 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38438 |
