Browse Forums Heating, Cooling & Insulation Re: Placement of insulation blanket under colourbond steel r 2Dec 15, 2010 10:18 pm Couple of E-vents http://www.colorbond.com/go/news/cool-running-no-moving on ridge or these http://universaltileventilators.com.au/ ... -vent.html to let heat and moisture out is what I'm going to use with Anticon blanket. Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8512 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14449 Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13728 |
