Browse Forums Heating, Cooling & Insulation Re: Ducted aircon after handover? Single story house 4Dec 01, 2010 2:46 pm 12 March 2010 - Land titles received 3 April 2010 - Signed building contract 14 April 2010 - Prestart 28 April 2010 - Loan approved 30 June 2010 - Slab completed 27 August 2010 - Brickwork completed 22 September 2010 - Roofing completed 30 September 2010 - Internal walls plastered 12 October 2010 - Lock Up 19 November 2010 - PCI 26 November 2010 - Handover 29 December 2010 - Moved In https://forum.homeone.com.au/viewtopic.php?f=31&t=32584 Re: Ducted aircon after handover? Single story house 11Jan 30, 2018 1:01 pm Hi all, I'm planning to have a ducted reverse cycle A/c installed in my home (construction to start in June/July). The problem is, the builder provides gas ducted heating as a standard inclusion and is not willing to give me a rebate on that if I don't want that as they say that they are required to have heating included, else they wont get the building permit/certificate. I don't want to have ducted reverse cycle A/c installed via the builder as i'm sure they will add at least a 3k margin cost and I cant be sure about the quality of their work. If I choose to install after handover via a third party then I would have simply wasted money on having gas ducted heating included as part of the standard build only to have it removed later when installing ducted reverse cycle A/c. FYI, I plan to have an all electric home with no gas. Does anybody have a workaround for this issue? Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8483 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4090 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15796 |
