Browse Forums Heating, Cooling & Insulation 1 Nov 28, 2010 6:54 am We are building with a colourbond hip roof......Our basic requirement is sarking[sisalation] under steel roof and ceiling insulation.....We would like to decrease the heat that will be transmitted through the colourbond roofing into the roof space as well as to provide sound attenuation from rainfall.....Suggestions please. Has anyone used Acoustiflex or Vapourcheck sucessfully in place of just the sisalation. What system or combination is the best value for money? Re: Help with roof and ceiling insulation please. 2Dec 12, 2010 1:30 pm Foil will block radiant heat entering. Acoustiflex to my knowledge is a mass loaded vinyl with no metal lining and is purely for acoustic insulation. I would foil under roof and acoustiflex over ceiling. But batts also help dampen noise. Re: Help with roof and ceiling insulation please. 3Dec 15, 2010 10:12 pm Anticon under roof with batts is a good combo IMHO Re: Help with roof and ceiling insulation please. 4Jan 07, 2011 9:12 pm Anticon as Lungy has suggested is ideal for metal roofs. Anti Condensation meaning the 'sweat' from condensation under the sheeting does not enter the roof cavity. That for the roof and some form of insulation for the ceiling. A whirlybird or some form of ventilator I suggest for metal roofs also (aiding in extracting heat from the roof cavity) There was (in my day) a polyester batt which for cathedral ceilings was ideal with a foil backing You get what you pay for! Found the answer. The recommended distance is .... 1 5988 Minimum overhang into gutter must be 50mm, turn down tool should not split the sheet. it seems wrong tool for the profile was used, the flashing cannot slope back. Rib… 2 2130 Building Standards; Getting It Right! We bought a house in 2015 advertised as a 7/2/2, 4br up, 3br down (7br), and to date, it’s a great house. However, we’ve just had it valued and it’s come in as a… 0 11988 |
