Browse Forums Heating, Cooling & Insulation 1 Nov 26, 2010 4:21 pm hi all I have no idea if this can be done so I hope I am explaining myself properly. We will be having two fireplaces downstairs and want to tap into that heat to heat upstairs. Is there a way of diverting that heat into "ducts" and dispersing it around? Thanks! Re: ducting heat around the house 2Nov 27, 2010 6:33 pm loretta hi all I have no idea if this can be done so I hope I am explaining myself properly. We will be having two fireplaces downstairs and want to tap into that heat to heat upstairs. Is there a way of diverting that heat into "ducts" and dispersing it around? Thanks! Saw a UK home show where they had something similar to what you describe. They had some kind of heat exchanger around the chimney which heated the water in their radiator system which was then pumped to their radiators. I also saw another UK show where they also used the chimney, but it was exposed on the 2nd level, which made it into a form of radiator. The difference to above is they didn't need heat exchangers or a hydronic heating system. Re: ducting heat around the house 3Nov 27, 2010 8:45 pm Hi AJW Thanks for that info. I will have a google and see what I can find. If anyone else has any ideas please post away! Re: ducting heat around the house 5Jan 03, 2011 8:47 pm Not sure whether you are planning open fires or woodheaters. For open fires with a brick chimney just make sure the brickwork is good quality and exposed on the upper floor and the whole chimney wall will act as a radiator. If you are having wood heaters You can box in the metal flue with enough room between the boxing and the flue for air to pass, and put a vent at the bottom and one at the top. and you shouldn't need a fan The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7020 Thanks for the photos. You need to know whether the inflow or the overflow pipe is leaking and this is a simple process of elimination. INFLOW: The vertical riser… 4 4658 There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually… 0 2969 |
