Browse Forums Heating, Cooling & Insulation 1 Nov 20, 2010 7:05 pm I would like to install a second hand evap cooler to replace my old one, which is starting to breakdown constantly. Has anyone done this? How much work is involved in taking the old one off, and putting the new one on? (Im thinking of something like a Brivis Contour) Re: Removing old Evaporative air con. Hard? 3Nov 22, 2010 10:33 pm We had our system removed and replaced with reverse cycle. It didn't take the guys long to do but there was 4 of them, although I don't remember how they got the system down from the roof. sorry probably not much help, but I like to leave the it to the people who know what they're doing Re: Removing old Evaporative air con. Hard? 4Nov 22, 2010 10:36 pm toc I would like to install a second hand evap cooler to replace my old one, which is starting to breakdown constantly. Has anyone done this? How much work is involved in taking the old one off, and putting the new one on? (Im thinking of something like a Brivis Contour) easy.. Re: Removing old Evaporative air con. Hard? 5Nov 23, 2010 6:40 am I had a look on the roof the other day - The air con seems to be pretty much screwed on to the steel 'dropper'. Im assuming the dropper is well and truly bolted to the roof frame, but I cant see it Re: Removing old Evaporative air con. Hard? 6Nov 27, 2010 10:05 am as long as the dropper that the air con is sitting on is in good cond it is very easy to do. But older air con dropper sizes are different to modern ones. you may need to get a adopter made to take the new air con. Air con installing companys dont charge that much for a change over and if everything is straight forward should only take about 1-2hrs to do. hope this helps. Im new here so HI ALL How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
