Browse Forums Heating, Cooling & Insulation 1 Nov 04, 2010 12:04 pm Im considering fitting a single split aircond for one of my bedrooms, and would like to know what you guys think of a wall mount vs a floor mount. Considering these two products: Daikin wall mount - FTXS25G rev cycle Daikin floor mount - FVXS25G rev cycle Room size is 12sqm. I intend to install the indoor unit at the corner of the room with the outdoor unit directly outside. Are floor mounted systems more expensive than wall mounted systems? Which is more efficient at directing air evenly around the room? 12 March 2010 - Land titles received 3 April 2010 - Signed building contract 14 April 2010 - Prestart 28 April 2010 - Loan approved 30 June 2010 - Slab completed 27 August 2010 - Brickwork completed 22 September 2010 - Roofing completed 30 September 2010 - Internal walls plastered 12 October 2010 - Lock Up 19 November 2010 - PCI 26 November 2010 - Handover 29 December 2010 - Moved In https://forum.homeone.com.au/viewtopic.php?f=31&t=32584 Re: Single split system - wall mount vs floor mount 2Nov 04, 2010 12:21 pm The 'floor' mount FVXS25G is almost $650 more expensive dealer price than the high wall unit... It is better for heating though as it opens up at the bottom when on the heating cycle and pushes hot air out around ankle height... Re: Single split system - wall mount vs floor mount 3Nov 04, 2010 1:21 pm hmmm that's quite abit more....thanks iceman I've got another issue as well with the positioning of the indoor wall mounted unit. I want to install the indoor unit and run the pipes back to back to the ground mounted outdoor unit. However, there is an external light point right behind here the pipes would exit the wall. Should i call a sparky to move the light point further away first, or can the a/c installer normally be competent to do this? 12 March 2010 - Land titles received 3 April 2010 - Signed building contract 14 April 2010 - Prestart 28 April 2010 - Loan approved 30 June 2010 - Slab completed 27 August 2010 - Brickwork completed 22 September 2010 - Roofing completed 30 September 2010 - Internal walls plastered 12 October 2010 - Lock Up 19 November 2010 - PCI 26 November 2010 - Handover 29 December 2010 - Moved In https://forum.homeone.com.au/viewtopic.php?f=31&t=32584 Re: Single split system - wall mount vs floor mount 5Nov 08, 2010 11:27 am ok great then, thanks 12 March 2010 - Land titles received 3 April 2010 - Signed building contract 14 April 2010 - Prestart 28 April 2010 - Loan approved 30 June 2010 - Slab completed 27 August 2010 - Brickwork completed 22 September 2010 - Roofing completed 30 September 2010 - Internal walls plastered 12 October 2010 - Lock Up 19 November 2010 - PCI 26 November 2010 - Handover 29 December 2010 - Moved In https://forum.homeone.com.au/viewtopic.php?f=31&t=32584 Move your linen into laundry and access laundry from your present linen space 1 8007 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8200 Thanks for responding. Do you know of anyone installing this product in Sydney? 2 3595 |
