Browse Forums Heating, Cooling & Insulation 1 Oct 01, 2010 12:46 pm I trying to decide whick system is the most water wise, economical and efficient. I have 3 systems in mind they are: 1. Brivis contour L43 Model with 9 outlets $5560. 2. Bonaire VSM65 with 9 outlets, rf controller $5145 3. BreezeAir EXH170D 8 outlets, harmony controller $5050 I live in Perth WA. Can anyone help me out please. Re: Which is the Best Evaporative cooling system 2Oct 03, 2010 11:06 am I personally think they are a waste of time and money! they don't work as Perth's weather is getting more humid each year. If you have timber floors -they will lift and split from the moisture from the evap You have to open doors and windows (which doens't make sence in 40deg heat) It doesn't cool the house down, just blows air from outside in These are from personal experience! Try refrigerated - if ducted refrig isn't in your budget you can get split sys - they work a treat - like walking in an icebox on those horrible 40deg days - set it at 25 or 24 deg and leave them on - you will never go back to evap Follow Feggle viewtopic.php?f=31&t=34992 Follow lilfeggle viewtopic.php?f=31&t=37149 Asbestosis Sux! Don't breath in Asbestos Re: Which is the Best Evaporative cooling system 3Oct 11, 2010 9:34 pm I am having the same dilemma! Although my quotes are more expensive e.g. $4,990 for breezair 170d with only 5 outlets. Who was your quote by? Good luck with your choice - i reckon as long as they come with a decent warranty any would be okay. Warranty supplied with ours was 7 years - Harvey Norman. Whatever you do don't go with a guy called Alwyn from Healthy Home Conditioning - found out just before we signed on the dotted line he a crook well known for running off with people's deposits! cheers. Re: Which is the Best Evaporative cooling system 6Oct 12, 2010 10:50 am The brivis is the better product IMO. I am a refrigeration mech and that's what I have in my current house and will put in next. The main difference between evaporative and refrigerated is the running costs. Evaporative costs about 20'cents and hour and refrigerated costs about 2 dollars an hour. Something to really think about n Re: Which is the Best Evaporative cooling system 8Oct 12, 2010 7:55 pm TheSquid The brivis is the better product IMO. I am a refrigeration mech and that's what I have in my current house and will put in next. The main difference between evaporative and refrigerated is the running costs. Evaporative costs about 20'cents and hour and refrigerated costs about 2 dollars an hour. Something to really think about n Yes I am with you too, i personally think Evap is a waste of money and after 2 hot summers you might acutally put in some split systems and by then your overall cost is $10k .. I had refrig in the old house and will be going with refrig again in this new build. We have evap in the rental we are in and there is nothing like refrig Follow Feggle viewtopic.php?f=31&t=34992 Follow lilfeggle viewtopic.php?f=31&t=37149 Asbestosis Sux! Don't breath in Asbestos Re: Which is the Best Evaporative cooling system 9Oct 12, 2010 8:42 pm lilfeggle I personally think they are a waste of time and money! they don't work as Perth's weather is getting more humid each year. If you have timber floors -they will lift and split from the moisture from the evap You have to open doors and windows (which doens't make sence in 40deg heat) It doesn't cool the house down, just blows air from outside in These are from personal experience! Try refrigerated - if ducted refrig isn't in your budget you can get split sys - they work a treat - like walking in an icebox on those horrible 40deg days - set it at 25 or 24 deg and leave them on - you will never go back to evap Each to their own. You are right about evaporative systems not working well on days of high humidity, the system must have an exit of some sort i.e doors, windows or if you prefer to keep doors and windows closed you can opt for ceiling vents, which will assist in further cooling your home by cooling the roof space. I've never heard of floor boards warping from an evaporative system, it sounds more like a construction or sub floor moisture issue to me, if your floors are warping from moisture inside your home you'd have a musky odor and mould everywhere. ..I've seen plenty of warped floor boards in homes without evaporative cooling. Re: Which is the Best Evaporative cooling system 10Oct 12, 2010 11:29 pm TheOK lilfeggle I personally think they are a waste of time and money! they don't work as Perth's weather is getting more humid each year. If you have timber floors -they will lift and split from the moisture from the evap You have to open doors and windows (which doens't make sence in 40deg heat) It doesn't cool the house down, just blows air from outside in These are from personal experience! Try refrigerated - if ducted refrig isn't in your budget you can get split sys - they work a treat - like walking in an icebox on those horrible 40deg days - set it at 25 or 24 deg and leave them on - you will never go back to evap Each to their own. You are right about evaporative systems not working well on days of high humidity, the system must have an exit of some sort i.e doors, windows or if you prefer to keep doors and windows closed you can opt for ceiling vents, which will assist in further cooling your home by cooling the roof space. I've never heard of floor boards warping from an evaporative system, it sounds more like a construction or sub floor moisture issue to me, if your floors are warping from moisture inside your home you'd have a musky odor and mould everywhere. ..I've seen plenty of warped floor boards in homes without evaporative cooling. ----------------------------------------------------------- true - finishing of your home is so very personal Follow Feggle viewtopic.php?f=31&t=34992 Follow lilfeggle viewtopic.php?f=31&t=37149 Asbestosis Sux! Don't breath in Asbestos Re: Which is the Best Evaporative cooling system 11Oct 25, 2010 4:49 pm Go Breezair or Braemar they are the best units on the market Brivis is a piece of **** the plastic casing will start cracking with in 5 years they are also very noisy and have **** back up service Bonaire is your builders type unit not to bad but cheap Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19516 It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9792 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13764 |
