Browse Forums Heating, Cooling & Insulation 1 Sep 29, 2010 10:47 am We have decided we want to insulate the internal walls of our home, the main reason being to reduce noise to the bedrooms. Can anyone recommend an insulation product that will effectively achieve this purpose? We plan to take a look at Bunnings tomorrow... Re: Advice please- Wall cavity insulation to reduce noise 2Sep 29, 2010 11:25 pm Like I said on the other thread...Acousti-therm is what we used. My reading lead me to rockwool but is is super expensive. RF Build: viewtopic.php?f=38&t=34534 Flooring: viewtopic.php?f=7&t=39733 Chat: viewtopic.php?f=36&t=53303 Re: Advice please- Wall cavity insulation to reduce noise 5Sep 30, 2010 9:05 pm There are specially designed acoustic insulators which provide some thermal insulation as well. Alternatively use a mass loaded vinyl behind the lining. Acoustic insulation is measured in STC reduction. Thermal insulation is measured in R values. Re: Advice please- Wall cavity insulation to reduce noise 6Oct 01, 2010 2:33 am b0b555 Would the 6 decibel reduction from Acousti-therm make much of a difference? I found that it has...we are not living there as yet but the dampening effect to the echo in the house is noticeable. RF Build: viewtopic.php?f=38&t=34534 Flooring: viewtopic.php?f=7&t=39733 Chat: viewtopic.php?f=36&t=53303 Re: Advice please- Wall cavity insulation to reduce noise 8Oct 02, 2010 7:51 am Are Pink SonoBatts a product that is as good as or better than the Acousti-Therm? This site lists a number of products: http://www.insulation.com.au/product.aspx?product_id=52 The Pink batts are much denser. Does that mean they will have better acoustic properties? And they seem to be around the same price. Re: Advice please- Wall cavity insulation to reduce noise 9Oct 02, 2010 9:06 pm b0b555 Are Pink SonoBatts a product that is as good as or better than the Acousti-Therm? This site lists a number of products: http://www.insulation.com.au/product.aspx?product_id=52 The Pink batts are much denser. Does that mean they will have better acoustic properties? And they seem to be around the same price. My reading tells me that denser is better for noise. RF Build: viewtopic.php?f=38&t=34534 Flooring: viewtopic.php?f=7&t=39733 Chat: viewtopic.php?f=36&t=53303 Nope, only on the inside, I've literally has my ears to the brick outside and can't hear anything. I can sort of 'reset' the noise by pressing firmly on the studs. This… 10 11732 Upgrading your windows to soundproof ones, like triple-glazed, can make a significant difference. While changing window… 4 11634 Hey guys, what’s everyone opinion on James Hardie linea direct fix to frame? Would this be the most common method and anybody ever had any problems down the track? 0 5132 |
