Browse Forums Heating, Cooling & Insulation 1 Sep 25, 2010 10:26 pm My Basix report says I need additional insulation of R1.30 (or R1.70 including construction) for my external framed wall that is clad with cement composite, Scyon. It will have villaboard or plasterboard in the internal face. How an I work out what R value the construction has? I'm thinking it might just be easier to put in R2 batts. Re: R value for timber stud external wall? 2Sep 26, 2010 8:19 pm Well from what you've said, if they say you need additional insulation of R1.3 or a total of R1.7 including construction, wouldn't that mean that the construction is R0.4? Or have I misread? Re: R value for timber stud external wall? 3Sep 26, 2010 9:11 pm Timber construction Thermal conductivity of materials NB R value is the inverse of thermal conductivity. You also need to adjust the figure because this is given for a 1 metre thick piece of material. Re: R value for timber stud external wall? 4Sep 27, 2010 10:41 am westy Well from what you've said, if they say you need additional insulation of R1.3 or a total of R1.7 including construction, wouldn't that mean that the construction is R0.4? Or have I misread? Correct Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: R value for timber stud external wall? 5Sep 27, 2010 1:09 pm I would have said that a Villaboard (or similar) outide, timber frame and gyprock on the inside would have an R value of about 0.5. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: R value for timber stud external wall? 7Sep 27, 2010 5:41 pm I definitely would. Have a look here http://yourhome.gov.au/technical/fs47.html#levels for info on recommended amounts of insulation for your location. Built with Sw1tch H0mes >Build thread< House status 15/12: Gates and A/C finally installed! Sep 09 Bought block, Dec 09 Engaged builder, Jul '11 Moved in Re: R value for timber stud external wall? 8Sep 27, 2010 5:45 pm I assume this is a new wall. In this case, you would need to fit the apropirate R rating of insulation in side the wall cavity. Have you installed sisulation ? Suburbia is where the developer bulldozes out the trees, then names the streets after them. Re: R value for timber stud external wall? 9Sep 27, 2010 7:52 pm I would be looking to install R2.0 wall batts - esp if you're in the more temperate region of nsw. (sisalation has no bearing on the R value in your type of construction) Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Thanks Pulse, thats really helpful and very much appreciated. Also thanks for the pointer on sheathing, thats me watching too many american youtube videos! 6 2806 As a tradesmen get a private inspector although I don't think there worth it in their profession themselves the reminder they serve to the tradesmen doing the work is… 3 27364 They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9605 |
