Browse Forums Heating, Cooling & Insulation 1 Sep 14, 2010 10:46 am we have just purchased a house but we don't like the position of the AC on the deck and want to move it to another location but closer to the internal unit. Is this possible. Can it be moved? If so, would we need both a plumber and electrician? Regards JT Re: moving split system AC 2Sep 14, 2010 10:57 am Moving a split AC is not as easy as it looks. you would need to move wiring, gas pipes (for the refregerant) and also ensure that a stable base is provided for the compressor. Personally, I would get the pros to do it. One more thing, you should get a cert of compliance from the plumber/electrician. God forbid that somehign should happen to your house due to you doing this yourself, your insurance company may decide not to pay up ! Suburbia is where the developer bulldozes out the trees, then names the streets after them. Move your linen into laundry and access laundry from your present linen space 1 8017 Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72342 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19521 |
