Browse Forums Heating, Cooling & Insulation 1 Sep 13, 2010 6:14 pm Hi Team We've got out plans back from our architect (about draft 100!) anyhow one of the things I really want to have is ducted air. Because of the height of the house (just shaves 8.5m) the roof pitch is only 10 degrees which makes it about 1 meter of cavity at the deepest point (skillion type). Does anyone have experience with cavity size and depth and installation of ducted units (the ceiling unit bit that is). Before I go further with finalizing designs I want to ensure all is well. best Regards Mark Re: Minimum roof cavity - ducted Air conditioning 4Sep 13, 2010 10:52 pm Then it *might* be possible but it's a seriously small space and I certainly wouldn't want to do it... You need to leave access for servicing of the unit as well as running ducts, dampers, etc inside the cavity before sheeting... Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8996 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5646 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
