Browse Forums Heating, Cooling & Insulation 1 Sep 07, 2010 12:06 pm I am looking for some advise on the effectiveness and efficiency of the units Porter Davis supply on these size houses. they have offered the Bonaire B3 30i for heating and B4 30i XA & 18kW for cooling is there anything else I should be considering or adding? I am concerend about location of temperature sensors / zones. Its all so confusing any help is appreciated. Re: PD marina 42 or other 2 story 40+ sq home 2Sep 10, 2010 11:12 am Hello Hantu, I understand your confusion and hope I can help you out. To answer your question, heating and cooling is house specific and is determined by our suppliers. If there are any additions to the house like a rumpus or higher ceilings then this can effect the capacity of the unit and might require an increase in kilowatts of the heating/cooling system. This can only be determined by our heating and cooling suppliers. So that I understand you better, what exactly are you concerned about in terms of the location of temperature sensors/zones? I hope this helps. Just so you know, you can contact your Site Supervisor or Customer Service Administrator to get a recommendation or send me a private message with your name and phone number and we can have a chat. Let me know if you have any more questions. Cheers, Jess. Porter Davis Homes Questions? Call 1800PORTER Mon - Fri 9am-8pm Sat - Sun 10am-4pm info@porterdavis.com.au http://blog.porterdavis.com.au/ http://www.porterdavishomes.com.au Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8505 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4099 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10051 |
