Browse Forums Heating, Cooling & Insulation 1 Aug 18, 2010 9:34 am Are inverters really that much better than fixed speed a/c? How much more do you think they are worth? 10%, 20%, 30%? How much power do they actually save in comparison to the fixed speed ones? Re: Inverter a/c Vs fixed speed 2Aug 18, 2010 10:19 pm pleasedontgo Are inverters really that much better than fixed speed a/c? How much more do you think they are worth? 10%, 20%, 30%? How much power do they actually save in comparison to the fixed speed ones? Yes they are, and no they are not. How long is a piece of string? If you are talking about HVAC, and comparing systems, then you really will need to supply some prelim specs on area that will be Heated / Cooled, type of home, orientation, window area and furnishings etc.. you get the idea I'm sure. Then also what type of heating / Cooling system you are considering. Electrically speaking only, and dependent on alot of factors, Inverters ( or VSDs / VFDs / Soft Starters etc ) can assist in saving alot of energy and $$. Again, it's all in the details. There are plenty of very knowledgeable folk on here that I'm sure would help in answering, if you gave them some more to work with. Plans Done Feb 2010 Permit Done 23 April. Set out Done. Scrape and Excavations Done. Footings Done May 10th. Now, to find a brickie.Got one! Sub-floor bricks & Garage Done - 13th June Sub-floor installed 28 June (?) Re: Inverter a/c Vs fixed speed 3Aug 19, 2010 12:58 am Inverters are most efficient when they are constantly working within their given output. If they are over-specced for the job then they start duty cycling and will work like a standard system. If they are under-specced they run continuously and the same issue occurs. Re: Inverter a/c Vs fixed speed 4Aug 19, 2010 4:59 pm We've done some math on this a couple of years ago. We found that the initial cost difference to go from a constant compressor to an inverter would take between 9 and 11 years to recoup in the savings in running costs. Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17591 So AFAIk the outcomes of the BAL ratings form part of a clause that allows them to pass these costs on to you. However the more relevant detail is how did it go from 19… 1 9163 My door tends to rub against the frame during winter and I'm looking to fix it so it closes smoothly. Looking online on Youtube I'm seeing methods to fix the alignment and… 0 692 |
