Browse Forums Heating, Cooling & Insulation 1 Aug 14, 2010 5:43 pm How do you maintain your aircon? Do you clean it often I mean vents, air outlets grills and other parts? It is said to reduce performance if the unit is not maintained I do every two weeks well my area requires that frequency Stonnington is very dusty. I use my shopvac in suction mode which does a good job. The rest of hardware I use the same in blow mode. Do you use another cleaning method? The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15841 retail its around double the price of a similar sized actron/dakin system from memory, They are excellent systems though. But with how builder gouge on AC/heating, you… 4 14796 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7269 |
