Browse Forums Heating, Cooling & Insulation Re: insulating double brick 2Aug 13, 2010 9:51 pm Where you are coming from is where you are going to... Re: insulating double brick 4Aug 13, 2010 10:59 pm Where you are coming from is where you are going to... Re: insulating double brick 7Aug 16, 2010 12:02 am I think insulation is the wrong solution. Need to find out how the moisture is getting there. If it is cold walls causing condensation more ventilation is required. Demolition August 2009, Construction Started September 2009, Completed December 2010 5 10585 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 11932 Double brick homes are the worst type of building conventions for the australian climate 1 1159 |
