Browse Forums Heating, Cooling & Insulation Re: Zoning advice for air conditioning my home 15Jan 06, 2011 9:35 pm As dymonite has explained inverter or digital scroll units (as Actron utilises) varies the output of the compressor to reduce energy costs by reducing input/output power as the unit reaches set point (the temperature you want) then floats just above and below this mark based on thermostat readings. The main difference with some of the Actron units mentioned is that they vary airflow also (Ultima) With traditional inverter and digital scroll units the compressor may 'ramp' down or up depending on conditions and set point but the airflow still only has a minimum and maximum so if you turned zones off, the compressor would ramp down but the airflow is still pumping out to perhaps the one zone you want running. The Actron Ultima addresses this and gauges both compressor and airflow output - big plus in my book You get what you pay for! Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8992 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5929 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 |
