Browse Forums Heating, Cooling & Insulation 1 Jul 31, 2010 11:09 am Hi guys, I have a Brivis 2PW 15 installed by a friend of mine, that I purchased off ebay. Its about 4 years old. The day installed, hooked up turned on and worked fine. Came home that night, switched on worked, turned up to 35 (highest setting, as system got hot and then hit 20, it switched off not getting to 35 on the thermo). Would not start up, so resetted unit by turning on and off 3 times in 5 mins. Did this a fews times. Didn't work, then uplugged for 1 min, reset Thermostat again. Didn't work, did it again and it worked, so left on for hours. Then turned off at bed time. Woke up this morning, turned on, set to 22 degress, worked fine, hit 22 then shut down as it was at desired temp. 2 hour later its 18 degrees and the system has not turned back on. Could the thermo be faulty? It is a electronic manual thermo, with on/off button and up and down button. Are there any other settings I could check? I noticed on the heater unit a little dial that is turned with a screw driver, could that have been accidently changed when installed? Thanks any assistance would be fantastic. I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7553 Okay sorry silly me, my wife has solves the mystery for me. It’s because the labels on the ports are all wrongly positioned by the builder hence it confuses me. 2 1387 Hi, just need to ask if anyone build with Central Properties in Victoria. Thankd 0 4027 |
