Browse Forums Heating, Cooling & Insulation 1 Jul 26, 2010 12:17 pm I just got a quote for the Actron ESP Plus system with the following specs: 12.5kW, 8 outlets, 6 zones, 1 return air, 50mm insulated ducting.....for $13,300 installed. Is this a fair price or am I being over quoted? Im in Perth by the way. 12 March 2010 - Land titles received 3 April 2010 - Signed building contract 14 April 2010 - Prestart 28 April 2010 - Loan approved 30 June 2010 - Slab completed 27 August 2010 - Brickwork completed 22 September 2010 - Roofing completed 30 September 2010 - Internal walls plastered 12 October 2010 - Lock Up 19 November 2010 - PCI 26 November 2010 - Handover 29 December 2010 - Moved In https://forum.homeone.com.au/viewtopic.php?f=31&t=32584 Re: Actron ducted quote....fair? 2Jul 26, 2010 3:19 pm Fair. Ours is around the same. But I think ours is the ultima? Do you mean 500mm insulated ducting? Re: Actron ducted quote....fair? 3Jul 26, 2010 5:55 pm aLLaNNa1 I just got a quote for the Actron ESP Plus system with the following specs: 12.5kW, 8 outlets, 6 zones, 1 return air, 50mm insulated ducting.....for $13,300 installed. Is this a fair price or am I being over quoted? Im in Perth by the way. Nothing wrong with that... Re: Actron ducted quote....fair? 4Jul 30, 2010 10:06 pm We are just outside of Canberra, this is out 1st Actron quote and will post our 2nd one when it come in next week. The following quotation is to supply and install an Actron Air SRD230C/SRM230E Ultima reverse cycle air conditioning unit ducted to 20 outlets. 2 - 200mm outlets to Lounge 1 - 250mm outlet to Dining 2 - 200mm outets to Kitchen 1 - 200mm outlet to Bedroom 2,3 & 4 1 - 200mm outlet to Bathroom and Ensuite 1 - 250mm outlet to Gym 2 - 250mm outlet to Theatre 2 - 250mm outlet to Study 1 - 250mm outlet to Store 1 - 200mm to Laundry 2 - 200mm outlet to Bedroom 1 1 - 250mm outlet to WIR The return air duct positions to be discussed/confirmed. Slimline grilles are included. All electrical connections are included. All refrigeration pipework and connections are included. The total cost would be $24,880.00 including GST (Twenty Four Thousand Eight Hundred and Eighty Dollars) Please note: This unit does not have the capacity to heater cool the home at one time,zones must be used. Included in the quotation: * Metal 2 way ceiling outlets -White * Slimline metal filter return air grilles - White * Uniflex Unilock S R1.15 Insulated Duct - 60mm Thick insulation. * BTO's (Branch Take Offs) to be insulated. * Zones as follows (The Actron Air Ultima unit can control a maximium of 8 zones) Zone 1 - Study Zone 2 - Theatre/Gym Zone 3 - Kitchen Zone 4 - Living,Dining,Bathroom Zone 5 - Bedroom 1,Ensuite and WIR Zone 6 - Bedroom 2 (Guest) Zone 7 - Bedroom 3 and Bedroom 4 Zone 8 - Store/Laundry Cheers, Darth Teddy Bear Hi, we live in an area where the black soil is prone to a lot of movement. We have an old 50's house with masonite everywhere and nails popping out, warping, rusted etc.… 0 4514 hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20921 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14325 |
