Browse Forums Heating, Cooling & Insulation 1 Jul 09, 2010 4:54 pm Hi Everyone, Im going for my Selections soon, was wondering whether or not to keep the standard heating, or upgrade to a bigger/better unit in the allegra range? Anyone got this or done differently? Also, cooling, should I go with EVAP cooling? Get M to do it? or do it later? Any other cooling options for a 20sq house? Thanks heaps!! All and any ideas/advise what be AWESOME!!!! Cheers Re: Heating and cooling with M...! 2Jul 11, 2010 8:45 pm personally, im thinking the same thing atleast with the cooling, you are better off going with the standard ducted heating and if need be just add a seperate heater for your living areas. this way you will have adequate heating to the whole house and have warmer environments to your general living. as with cooling, you will need to decide if you want a fully ducted system to the whole house or go reverse cycle system. it depends on your needs and wants. getting M to do it while building means one less thing you have to worry about after you move in Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 4890 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10051 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6183 |
