Browse Forums Heating, Cooling & Insulation 1 Jun 28, 2010 2:38 pm Gday all and sundry, Just trying to figure out if its cheaper to run my $20 1800 watt Kmart blow heater than it is to try and heat the room with my brand new 3.5 kw LG Split Cycle Heat Pumps? So far the little Kmart Blow heater is winning and heats a 15x30 room nicely in about 20 minutes while the Heat Pump is still battling to heat the room 4 hours later. Air temp at the blower on the Split is around 34-38 degrees when running at its best but it just dose not heat the place up? Are these Heat Pumps just a load of Hype? Have not had a summer to test the cooling side of the units yet Has anyone else found this or are all my brand new LG Inverter Splits stuffed Cheers Re: How many Watts make up a KW in Air conditioning terms? 2Jun 28, 2010 2:56 pm It sounds like your tubing may be compromised. Get a tech. to measure the heat / cooling output against specifications. Re: How many Watts make up a KW in Air conditioning terms? 3Jun 28, 2010 5:45 pm Heat pumps should provide at least 3x heating output for electrical input. I agree with EveDweller, something is wrong with your unit. Anybody know any good and reasonably priced Air conditioning contractors/companies that could install a ducted air conditioning system in the Central Coast NSW for a small… 0 8985 I believe that liquidated damaged should be amount of actual loss to the owner from the delays. The issue in all of this is building industry lobbying and contributing to… 5 3415 Not sure who you're building with, but I moved in recently to a 11month scheduled, 8 month actual build on the South coast/Illawarra NSW 3 5908 |
