Browse Forums Heating, Cooling & Insulation Re: DIY - renewing ceiling insulation and adding sarking 2Oct 15, 2007 8:57 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: DIY - renewing ceiling insulation and adding sarking 11Oct 18, 2007 4:52 pm 3timesbuilda Consider upgrading your old AC unit, the new ones are considerably more efficient so you will get more cooling for less $$s. I'm trying to do this with as minimal outlay as possible. But I hadn't thought of upgrading the A/C. I know split systems are available with inverters for cheaper running, but not sure if I can get an inverter in a ducted system. Last year I'd already considered upgrading the temperature sensor/controller as it's the old Email round knob with heat/cool switch, and not programmable like modern controllers are. Quote: Also consider putting in a roof airvent (one of the round spinny things) to let excess heat out of your roof space. I was going to mention that but didn't want to get too off-topic. I expected lots of responses by mentioning it as I have heard so many conflicting stories about those devices, which is also one reason why I didn't consider them. Quote: You may also consider putting bats between the sisilation and the roof tiles? Should provide some insulation before the heat gets into the roof space. There isn't any sisalation installed. That's why I mentioned the sarking. (Assuming they're one and the same) Found the answer. The recommended distance is .... 1 5989 Building Standards; Getting It Right! Hi all I’m in VIC and had some storm damage in my garage a month ago. Gutter found not fit for purpose. Insurance company saying the guttering and flashing to be fixed… 0 11717 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4714 |
