Browse Forums Heating, Cooling & Insulation 1 May 27, 2010 8:05 pm Hi everyone. We are installing ceiling fans to the living areas and bedrooms of our home (currently being built). We have 9 foot ceilings and the shaft of the fans is only about 10 cm long. This would look ridiculous. What would be the standard length required if we extended the shaft? I have purchased 900 mm extension rods which can be shortened to any length. Ceiling fans are Martec lifestyle range. Just completed build with Hallmark Homes I installed a ceiling fan under a ceiling rose. However it obviously doesn't sit flush against the ceiling so wobbles and makes noise while turned on. Would appreciate any… 0 8835 what's the rationale on this? In my mind, the risk weepholes mitigate isn't solved by acrylic render. 9 42334 Many thanks for your reply. Yes I am concerned with the work done. I have another problem with my contractor and I hope this next investigation and review with the… 2 19865 |
