Browse Forums Heating, Cooling & Insulation 1 May 24, 2010 11:18 am Hi All, Finally, getting the gas log flame fire installed into the built recess where we currently have a TV(37" LCD - wall mounted) I am looking for inspiration - the fire is a Regency P36 (w915mm x h775mm) - the recess is 3070mm with a 28c bulkhead. We bought this model because it was "direct vent" flueing out the back rather than though a chimney stack - upon bringing it home, it appears we need an 1100mm clearance for the fire - vent. This has changed the concept we had of having cabinet makers build a cabinet just above the top of fire and across the recess - it means that the top of cabinet will be really high and television mayu have to move upwards which will be too high. Can anybody direct me to websites with cabinetry ideas for this sort of issue? Many thanks We are tossing up between a Jarrahdale radiant wood fire (the Pioneer) and a convection wood fire (Innovator or Countryman) but cannot decide on which type of wood fire is… 0 5251 Need some advice. Living in a townhouse with one common wall, recently we have discovered that the fire separation wall is incomplete and on further investigation, support… 0 3863 |
